12-09-2022
11:20 AM
- last edited on
07-07-2023
12:38 PM
by
I am considering moving my wife onto my plan and creating a group, she is not with smarty at present, can i get the double data offer as it shows for new usrs only?
12-09-2022 11:50 AM
Hey keithwal_608914
to use the refer a friend link she would need to join SMARTY as an independent user using the refer a friend link and then you can invite her to the group
12-09-2022 11:29 AM
Hey keithwal_608914,
yes! she would still be considered as a new customer even though she is joining a group, here are some more details on how to join a group https://bit.ly/3HnoRu7
12-09-2022 11:44 AM
if i invite her as a new user, via my invite link, can i get the £10 incentive.....every little helps !!!
12-09-2022 11:50 AM
Hey keithwal_608914
