georgek_1669514
26-06-2024SMARTY Pioneer
4g not working when browsing I either get no sound or absolutely nothing
1 Reply
- LinseySMARTY Moderator26-06-2024
Hey there 👋
We regret to hear about this situation and apologise for any inconvenience it may have caused.
Can you please do the following recommendations:
- Restart your device.
- Make sure you are using the correct SIM card (Not the Bonus SIM)
- Ensure APN settings have been set up correctly: My SIM is not working
- Test SIM in another device to see if it connects.
- Make sure your device is 4G VoLTE compatible: Checking if your device is 4G-VoLTE compatible
- Check that the coverage in your postcode is covered: Coverage checker
- Check for any potential maintenance in your area: Network status checker
If none of these help, then please get in touch with our customer care team: Contact us
They will have the option to escalate the issue to our specialised network team for further analysis. 📱
